I connected my two batteries like so:
Negative cable to one battery then another wire from that battery to the other batteries negative terminal
Positive from one battery to #1 on the perko switch and positive on battery two on #2 perko switch
Connected the positive cables to the common switch on the perko switch
My question is that I hear people saying that they will start with #1 then as they are moving put the switch on all to charge both batteries. Then when when you stop put the switch to #2.
My question is if I put the switch to all. Doesn't it change it to 24volt and could ruin my batteries and anything else? Or will it be ok and charge both batteries at 12 volts?
Thanks
Thanks
