Question on propellers
sidechoke67
When replacing a propeller, is it better to get one that fits "naturally" onto the outdrive vs. getting one that requires a hub kit?
I have a Volvo Penta outdrive, and I could buy a Volvo prop for $164, or buy a Michigan Wheel prop + hub kit for $169. Does it make any difference which one I go with?
This is the first propeller I'm replacing, and would appreciate any info.
Thanks!
5150abf
Re: Question on propellers
I have never heard anything bad about hub sytems but I always go on the premise that more parts mean more things to break.
The Volvo prop is probably a higher quality peice, I had one Michigan prop and didn't like it at all, seemed to be really brittle, snapped off half a blade first time out.
Others here really like them and have run a long time with no problems.
I think either is fine but I personally would go with the Volvo part.
Feeling a little better today I hope.
sidechoke67
Yea, a little bit, thanks. I looked at my boat this morning, hoping to find it had been repaired overnight, but no such luck.
Thanks again.
Ayuh,.......
It Doesn't matter in the least......
As long as the Prop,+ It's Hub Kit, fits the drive your installing it on.......
tashasdaddy
i had trouble with a couple of hub kits fitting me volvo sx drive, finally when with a volvo prop.
vess
Sidechoke- sorry to see the damage, but that is common. I did the same last year. Locally I called around to see about getting it repaired to keep as a spare, but it was at least $75 to repair, so I ordered a new Michigan Wheel for around $85 on line. I also ordered a composite prop as a spare to keep on board- it works great, and costs less than the aluminum. It is sickening at first, but you will be fine. Happens to all of us at one time.
Varago
With a new boat this year, I have 3 old props, they are the pitch size I use on the new boat but wrong spline, one SS was over $600 and the used market for it is zip.
I wont buy a prop that does not have the Merc Flo-Torq II hub system. Michigan Wheel and Turning Point both are now using it.
Dave
