question on transom plate part numbers
silvert
I have to replace my transom plate. The pn on mine is 44116 c5. I've fpund a few of those exact part numbers, as well as 44116 c1, c2 and so on. Also have seen 44117a8 which looks similar. Mine is for a bravo 3. Are all these interchangeable? Tia
achris
More fish than mountain goat
What is your gimbal housing serial number?
achris
That serial number comes up as an Alpha One Gen II... You say you have a B-III?
The good news is that the Alpha Ones (from 1983 to present) and the Bravos (from 1988 to present) share the same inner transom plate. So -44117A8 is the correct number.
The number you're seeing on the plate is the casting number, and it's usually not the part number. It may bear a similarity, but you can't use it to order a new part.
Chris.....
