Question on Very Old stern drive
CraigBarnard
I have what I think may be an original mercruiser stern drive and the upper and lower gear oil oil chambers are two separate chambers.
When I checked the upper chamber this afternoon (after draining the lower) I heard air being sucked in as if it where under a vacuum.
I decided I should remove the top cover and have a look inside. The upper chamber was empty.
I was wondering if anyone knew of a common cause for this to happen.
Thanks
GA_Boater
Craig - The guys in the Mercruiser section might be able to help you a bit more. They will probably want serial numbers. Good luck.
Watermann
Normal to have that happen. it's one cavity, the bottom hole in the gear case is the drain/fill hole and the top one in the upper is the vent hole. Just like on an OB you fill from the bottom and oil runs out the top hole.
Fishermark
I could be wrong.... but I believe the very old outdrives had two separate gearcases - an upper and lower. Each had its own fill and vent. A little more research is probably a good thing.
CraigBarnard
Thanks I believe they are two separate chambers as well. the newer ones have a single chamber as Waterman suggested.
My outdrive has two fill holes and two level check holes on the upper and lower sections of the drive.
Bt Doctur
from manual 1 , does list 2 amounts of oil
