Question re: dual cable steering. '86 Blackmax XR-2 150
CWKboat
Hello, just bought this engine to put on a 2002 Larson 20 footer. The Merc came off a bass boat and had dual cable steering. The current Larson it's going on has a single cable helm. Can I just use one cable on this setup with the Merc as it will be low-mid 40s WOT in all likelihood? I assume the dual cable is for higher speeds?
Thanks for advice!
1nebel0
Re: Question re: dual cable steering. '86 Blackmax XR-2 150
Yes.... save your money... the dual cable gives you more control for the heavy motor however at those speeds you can turn it with one cable.. I have a 19ft pickle that does 90 with dual cable and you cannot turn it do to the torque at those speeds.. I also have an 18ft checkmate with a 175h.p. and only using a single cable with no problem. The dual helm and additional cable are not cheap.. best steering is hydraulic which will cost you a grand plus install...hope this helps...Steve
