firemanfitz
Thread starter- Joined
- Aug 14, 2009
- 36
Can a bad solenoid cause the main engine fuse (20 amp) to blow everytime you try to start it.
tx for info. Will try in the a.m. Just darn tuckered out now.The fuse feeds the ignition switch and the purple wires off of the switch. If you had a defective guage powered by a purple wire, it could blow the fuse when you turn the switch to on. You could use a ohm meter and check the guages for a direct short and tell which cuage is causing the problem.
