Lukelona
Thread starter- Joined
- Mar 9, 2013
- 449
Just bought a 99 Larson 20' bowrider with a 1980 mercury 140 outboard
Story goes, it ran end of last season, but he was having problem reaching normal speeds.
It sat for the winter, I bought it yesterday but we couldn't get it to fire up. Didn't try too hard, just primed it and cranked for a min or so.
Now..... First question- when priming bulb, it doesn't "pump up" and get hard like I'm used to on previous smaller outboard motors. Instead it eventually leaks gas out of center of carb. Is this normal? Or should it pump up hard like I'm used to?
Second question- never had one of these engines so I'm not sure how much work is too much to put into it. It needs a prop, it's banged up and bad shape.
I have a spare Mercruiser SS prop in the shed. Are they the same? Will it fit?
My SS just needs a new hub, but cheaper than buying new prop I guess.
3rd question- the throttle is stiff, and he thinks that cables had to do with not reaching higher speeds last season. It appears they used Original controls to the boat (not positive)
But as stated it has a totally different motor now.
They're quicksilver controls with the fast idle lever and tension adjust knob on front.
I'm not sure how to choose a replacement cable to fit and work properly
Any help appreciated as always, thank guys and gals
