DamianJP
Thread starter- Joined
- Mar 25, 2008
- 612
I have some questions about a rebuild.I have pics this time to help make it more neat and more to the point.
First is this a bad thing, the wrist pin on this one piston moves freely.
Top crank bearing housing
Can I rebuild this roller bearing with new needle bearings , oil seal and other seal? They want alot for the housing.
Middle crank bearing housing
Same with this roller bearing , can it be rebuilt with just needle bearing? The housing is alot cheaper than the top crank housing.
Bottom crank bearing housing
Can get for $22, also need a bearing puller. What kind do I need to pull it?
Crankcase 2 "String" seals
Were can I get these seals from?
Both the connecting arm needle bearing assemblies Im gonna do.
Again are these items you normally do when your in this area and/or how can I tell if they need replacement of not? I have a OEM manual that focuses on this motor %100, but any hints or advice on have to avoid certain pitfalls in this area of work is greatly appreciated. First time im doing a rebuild.
Thanks,
DamianJP
Thanks,
DamianJP
