Mark42
Thread starter- Joined
- Oct 8, 2003
- 9,334
One of the specs available from Toyota in the sales brochure says it can tow up to 3500 lbs. So I was confident that towing with the Sienna would be a pleasant experience, knowing that I should be able to tow my 2000lbs gvw Bayliner trailer and carry the family and gear and be well within the capacity of the vehicle.
But after getting the vehicle, and reading the owners manual, I find a number of restrictions and suggestions that are really bothering me. I am rather dissatisfied at what I found in the 07 Sienna owners manual (bold by me).
1) (pg 424) If towing a trailer and cargo weighing over 907 kg (2000 lbs) it is necessary to use a sway control device with sufficient capacity.
Exactly what is a "sway control device" and why is it needed over 2000 lbs?
2) (pg 425) Toyota recommends removing the trailer hitch whenver you are not towing a trailer to reduce the possibility of additional damage caused by the hitch if your vehicle is struck from behind. After removing the hitch, seal any mounting holes in the fehicle body to prevent entry of pollutants such as exhaust fumes, dirt, water, etc
I first thought they meant to remove the draw bar. But no, they want you to unbolt the whole hitch and plug the holes. This is a joke right? They can't possably be serious. Anyone here remove their hitch when not in use?
3) (pg 427) In order to maintain engine braking efficiency, do not place the transmission in "D". (This is listed under the heading of "Trailer Towing Tips". )
This is the ONLY reference in the entire manual about towing and transmission gear "D" I can find. It seems to suggest that the only reason for not towing in "D" is for engine braking effeciency. It does not mention possable damage to vehicle or drivetrain will occure if towing in "D". Item 4 below seems to support that braking efficiency is the only reason to not use "D".
4) (pg 428) Slow down and downshift before descending steep or long downhill grades. Do not make sudden downshifts.
This seems clear enough. Use the engine braking force to prevent over heating the brakes.
5) (pg 428) Do not exceed 72km/h (45 mph) or the posted towing speed limit, whichever is lower. Because instability (swaying) of a towing vehicle increases as the speed increases, exceeding 72 km/h (45 mph) may cause loss of control.
Is this a general warning about vehicle sway or is the Sienna specifically subject to vehicle sway when towing over 45 mhp?
I am sure that Toyota wants to ensure that their buyers have safe towing experiences, and hence suggest towing at no more than 45mph, and to possably reduce law suits or liability. At least I hope that is why, because towing at 45 mph on the Long Island Expressway (in NY) or Rt 80 in NJ at 45mph will get you run off the road! Plus it will add about another 2 hours to my typical 4 hour trip to the beach.
6) (pg 426) If the total trailer weight exceeds 453 kg (1000 lbs) trailer brakes are required.
This one bothers me. Generally speaking, trailers (boat and camper) do not come with brakes until they reach the 3000 - 3500 lbs range. The majority of States do not require brakes on trailers until they exceede 3000 lbs, although there are a few states in the 1500 lbs range (NE and GA). Adding brakes to a trailer means new axle, hubs, brake drums, bearings, wire harness changes, etc easily costing $600 in parts to do it right. Is this a blanket statement to reduce Toyotas liability or is the braking ability of the Sienna so poor as to warrent brakes on trailers over 1000lbs? It does have 4 wheel disk brakes.
I have towed both my boats with our 97 Mercury Mountianeer (with over 200k miles) and our 98 Lincoln Town Car (with over 140k miles) with no special towing provisions or restrictions, towing in "D" (overdrive) and at speeds of 60mph with no sway and no issues or problems. Neither vehicle has had any transmission problems. So I am rather annoyed that Toyota wants to put restrictions on towing with the Sienna, which should tow at least as well as the Town Car.
Feel free to comment on any or all of these issues.
Thanks,
Mark.
Thanks,
Mark.
