Jeepster04
Thread starter- Joined
- Jan 5, 2009
- 481
I post a thread last fall(I think) about having some issues with our engines stalling out while making low speed maneuvers in our boat. Sometimes they would just die and other times they would die while shifting. Its finally warmed up enough around here to de-winterize everything. Fired them up without much trouble after sitting all winter and changed out the distributor cap, button, spark plugs, water impeller, oil+filter, water/fuel filters, and sprayed some carb cleaner in the carbs to clean them up some. They will start right up with just a tap of the key which is better than its ever been but one, the idle kinda floats around. We adjusted the idle to around 750 but it floats between 700 and 800rpms. Two, the fuel filters were nasty. Hardly any water but it looks like its been AWHILE since the filters were changed. Dumped them out in a jug and it had a lot of crap in it, looked like mostly rust from the filters themself. Didnt get around to checking the filters in the carbs(I think they have them in there) so Im not sure how much crap is in those. Figured the floating would be from dirty carbs? Didnt get a chance to take it out of port after working on the engines, they seemed to shift ok without stalling while in dock though.
Either way, wanted to get some heads up on how difficult it is to rebuild these carbs. Im not 100% sure but I believe they are Rochester carbs, can anyone confirm that?
Here is the SN for one of the engines.
500A
4100113751
868263
Ive got the OM but it talks about 3 different carbs.. A holley, rochester, and nikki. From the pics it looks like a Rochester and says thats what a 500A had. Best place to get a rebuild kit?
One last question, is an intermediate bearing the same thing as a gimbal bearing?
Thanks for any help.
500A
4100113751
868263
