oops!
- Joined
- Oct 18, 2007
- 12,932
i have 2 questions i need your consult on please...id really appreciate it...
they are theroitecal....
#1...
i was thinking of adding a "cool can" like thingie to my boat...
(we used cool cans on race day to chill the gas in our cars, in the seventies)
take a refridgerator evaproator...(an aluminimum raditator like thingie)....
and put it in the bottom of my ice chest....(built in to the bottom of my boat)......
run the fuel lines thru it and chill the gas.....place a insulator around it and run it to the pump...then carb...
or...run it from the pump to the cooler then to the carb.....30 feet of run....(will the pump be able to do it?...(pressure?) )
the real question is ....will it do any good..?? how much benefit will i get...a .....03 percent increase in power? is it worth it?
question 2....
wanna do the same thing with air to the motor...same system...use water thru the evaporator...pump it to the back of the boat....run it thru another evaporator and use several fans to blow the now ice cold air into the specially made.... sealed air intake chamber around the carb.
question is .....it will add twenty pounds of weight !!!! will the benefit out weight the cost of the weight?....
thanks guys....
oops
#1...
question 2....
thanks guys....
oops
