Questions for the Gel coat experts.
mogfisher
I'm getting ready to re gel the hull on my 18' bass boat. I have questions for the gel coaters.
  1. How do you know how thick you are spraying?
  2. I have a "dump gun" or "cup gun". Is this better or worse to use than an HVLP with a 2mm nozzle?
  3. Can I spray some poly resin on a test piece and have it be close to what gel will spray like?
  4. Is a guide coat a good way to know when to stop sanding on gel?
I see the cup guns are more expensive than the others so that means they must be better right!? I have a ES Manufacturing G100 gun shown below.
Seems rather crude but I know I'm going to be sanding for days anyway. Seems like this kind of gun might be better for applying into a mold and a regular spray gun might give a smoother finish. Is it worth buying a new gun for the difference? Luckily a lot of my hull is flat so I can DA a lot of it.
I was hoping that I can test spray with some poly to get a feel for how gel might spray out. Maybe they are not similar enough, I don't know.
Thanks for any input!
Adam
ondarvr
Re: Questions for the Gel coat experts.
For an actual example and explanation of spraying gel coat read the "hull extension" thread, it will give most of the info you need.
A dump gun works OK, the down side is the surface may be a little rougher with it though.
