Acpics80
Thread starter- Joined
- Mar 17, 2016
- 41
Hi guys, a few questions about finishing the new decks for my Sea Nymph. I've cut the new deck out of 1/2" exterior grade plywood and sealed the top and bottom surfaces with 2 coats of "old timer's formula" and the edges at least 4 times. I then coated all surfaces with two coats of spar varnish, but now I'm a bit undecided on how to "finish" them so I have a few questions.
Has anyone used any type of paint over spar varnish? I'm assuming for this to work you would need to sand the surfaces well and then use some type of oil based paint. A friend of mine has some extra textured marine decking paint so I was thinking of trying some of this on a sample piece. Just curious if anyone out there has done something similar.
I also found a product at the local hardware store that is essentially sand and you mix it with your paint or varnish and then apply a coat. I tried this on a sample piece and it actually turned out very nice. I think it would be a great non-slip surface I'm just not sure how I would like the look of a plywood deck.
Lastly, I'm a bit confused on how to seal the seams between my deck pieces and around the edges of the deck with the painted aluminum hull. I've seen the term "PB" tossed around on here but I'm not sure what exactly that is other than referring to the consistency. Does anyone have suggestions on what I can use on the seams in order to seal up the deck?
To secure the deck I plan on using ss screws with finishing washers. For the majority of the time this boat will be in the salt and fishing so carpet is out of the question for me.
Thanks in advance for any help, tips and suggestions!
Acpics80
Picture of the new deck before it was removed again to seal:
Acpics80
