Brock.Ward
- Joined
- Jul 1, 2010
- 148
So I rebuilt my 1965ish 45HP West Bend(Kinda), cleaned carb, new fuel pump diaphragm and gasket, new starter, new impeller, new points, new plugs, everything else tested works good. Been out on lake a few times runs good but has a lot of starting issues. Few questions, what is the flot next to carb for and what should it be set at? Yesterday we had issue after issue starting, i had to adjust the throttle sometimes and open it a touch to get her started also would have to adjust carb pin 50 times and sometimes float it seemed to start her, in the end starter was too hot to start andi had to get towed in
any help on this engine or rebuilding carb or adjusting float would be appreciated. Thanks!
