Re: QUESTIONS, when building an enclosed hardtop cabin to replace canvas...
Be careful what stripper you use on the boat, you can destroy the fiberglass. I'm assuming this boat is fiberglass right?
the boat is fiberglass. I have sucessfully used jasco and tuff strip before without any problems. they are not the envirment friendly type, but they remove paint good.
i am not sure what would happen if you left it on too long other than drying out, but i dont intend to let it stay on for longer than it needs to work. a bit of softening in the paint and a hot pressure washer will take care of the rest.
they use paint stripper of one type or another in strip shops for removing paint from body panels, fiberglass and steel panels... some parts they dip and others they spray it on, then steam it all off with the paint.
if anyone has had any bad luck with a paint stripper dissolving fiberglass, i would be interested to know the brand of the stripper, because it will be some of the good powerful stuff that I could use from time to time...
