questions...
Js34gl3
I have a 14' aluminum boat starts off as a v-hull but ends as a flatbottom on the bow i have a '66 johnson 33hp RXE-13...
For a fuel to oil ratio what do i need, 50:1?
and I would like an updated prop couldn't tell you what's on there now... But how do I go about getting a good prop for that particular setup as noted above?
Scaaty
Re: questions...
Think ya mean stern, not bow..anyway..50-1 fine Can't help on the prop..post that question in the prop forum..
HighTrim
Re: questions...
The right prop for you is based on alot more than just the boat you're running it on, such as weight usually on board, use of boat, setup, etc... The guys in the prop forum can help like stated, but here is some reading for you. Good luck.
"http://www.marinedepo.com/proschool101.html"
"http://www.bogerprops.com/props101.html"
Js34gl3
Re: questions...
thank you for the information, i wasn't sure about fuel to oil ratio because of it being an older motor.
