I was getting rid of my metal OMC tank in favor of a plastic Tempo tank. I noticed that the Tempo tank connector has the valve pin in the middle of the supply tube, rather than on the side, where it is on the OMC. Does this mean I have to use the Tempo quick connector, or will the OMC quick conncector still work with the Tempo tank conncector? I'm not clear on whether the check valve plunger on the OMC quick connector will push the valve pin all the way in on the tank conncector.
