Quick Disconnet Thru Hull Fitting
Mordekai
Are there such things as quick disconnect thru hull fittings?
Basically i'm looking to connect up the inlet of my wash down pump to the thru hull fitting on the inside then on the outside would be a quick disconnect that i would use with a weighted hose to use as a water pick up and remove when done.
Does such a thing exist?
Thanks.
H20Rat
Re: Quick Disconnet Thru Hull Fitting
Thanks.
Sounds like a lot of work... I'd just go with a good quality metal thru-hull, connected to a host with a rise that goes above the waterline. (assuming the wash down can self prime for a short lift at least, most can)
