quick question about the sterndrive
turbocorrado
its leaking drive oil between the driveshaft housing and gear case, im assuming its just an o ring? or is there an actual gasket soemwhere, i looked at an exploded view, but ive never had it apart so im not sure where i need to be looking
thumpar
If you haven't changed the impeller lately just get the impeller kit. The quad ring comes with it.
Bt Doctur
Without knowing the exact type of outdrive, it `s hard to give the correct answer
