Re: quick start on johnson
If, when the engine is first cold started, the ignition is turned from the off position, and
If the powerpack is good, and
If the temp switch is connected, and
If the temp switch is good, and
If the cylinder head temperature has stayed below 105 degrees F., and
If the engine has not gone faster than 1100 RPM, then
The engine should be in QuikStart mode.
Otherwise, QuikStart should have released.
You now need to acquire a Factory Service Manual covering your motor and perform a Linkage and Synchronization as defined in section two of the manual.
I noticed that Searayman has a new one on Ebay for about 35% off list price:
http://cgi.ebay.com/ebaymotors/1995...70047103279QQptZMotorsQ5fManualsQ5fLiterature
http://www.outboardbooks.com/index.cfm?fuseaction=search.main
