Re: Quick Timing Questions
The reman'd head did not have a model # on the freeze plug, but I was roughly able to ID to a pre 1984 V4 115 crossflow flatback (recirc routing through #1 and #4 bypass covers) For reference it is replacing a 84 1.6l Sea Drive flatback.<br /><br />Previous failure was due to carbon build up on exhaust side of #3 cylinder (is coking the same thing?). I don't thing it ever saw a drop of engine tuner, which I now plan to do religously at least every 50 hrs.<br /><br />I've gone though the standard list of items, rebuilt carbs, replaced t-stats and impeller, <br />inspected all hoses / connections (all new last year with VRO), etc.<br /><br />Timing pointer adjusted to TDC for #1 cyclinder, adjusted the timing to approx 26 degrees (using J. Reeves static timing method, adjusted from approx 24 to 22 deg.)<br /><br />In board tank is mixed with 50:1 to run in parallel with VRO for break in. Started and idled motor on the muffs to verify warm up / cooling (no issues). Verified spark (no issues). Checked head bolt torque after first warm up / cool down (a few required some additional torque).<br /><br />My ??????'s<br /><br />Why would retarded timing be safe (less stress somehow)?<br />Is the timing adjustment necessary?<br />26 deg would be retarded (as opposed to 30 deg?) <br />How long shoud timing remain retarded (if at all)?<br />Can I expect a WOT RPM difference for the 2 deg retarded?
