quick volvo engine question
bayliner09
i have a aq120b motor that i recently rebuilt and i cant store it in the boat because it is having the deck rebuilt so the motor is going to be stored under my lean to and my question is what do i need to fog it with to keep moisture out of it because it doesent have intake manifold on it yet and no oil in it ether or can i leave it without
Re: quick volvo engine question
Ayuh,... I'd mothball it with some sorta spray oil,...
Fogging oil sprayed anywhere, 'n everywhere possible would work...
Squirt a shot into each cylinder, 'n roll it over by hand...
Why is the base still dry,..??
I'd fill the oil, mothball it, 'n plastic bag it... Then tarp it, twice...
bayliner09
the only reason its still dry is it was a last minute desition to do the floor rebuild so it was going to go straight in thanks for the advice
tpenfield
My engine is staying in the garage for the winter . . . all oiled up, fogged, drained and kept relatively warm.
I'd do everything you can to keep your freshly rebuilt engine protected.
(my apologies for posting a picture of a Mercuiser in the V-P forum :p )
Don S
Make sure the block is drained of water, that would be your biggest problem. Rather there is oil in the pan or not doesn't mean much for the rest of the engine, the crankshaft nor anything else is in the oil when not running.
Keep water off the engine and keep it covered as Bond-o mentioned and you should be good to go. Just don't cover it with clear plastic sheets, they act like a green house. Dark green trash bags work much better.
