bonz_d
Thread starter- Joined
- Apr 22, 2008
- 5,276
This is the 14' aluminum rowboat I inherited that was in sad repair when I got it. I have posted a couple times about this and will link them here and then use this topic to add updates as I go. They can be found here.
http://forums.iboats.com/forum/gene...gine-topics/9916031-14-row-boat-id-crestliner
http://forums.iboats.com/forum/boat...and-hull-repair/9918865-easy-transom-question
As I stated in the other topics this boat came with no ID what so ever. No registration numbers and no HID either. It's origin and history are still in question though thru searching I think I have it narrowed down to a pre 1970 Rich Line. All I've seen post 1970 have a lapstrake design like the MirroCrafts. Yet by the drain located in the bottom I'm more inclined to believe it's pre 1960's.
Well I finally almost have the transom wood replaced. Because all the wood was missing when I got this it was a bit bent out of shape and the one corner bracket that I had to remove along with the corner caps don't quite line up with the original holes.
Used 3/4" 5 ply Premium ABX ply from Menards, treated it with the old timers recipe and then given 3 coats of spar urethane on each side with the ends getting a coat while doing each side. So the ends have 6+ coat.
Still need to find handles for the transom and reattach the corner caps. Then I'll start to think about paint. So here are a few pix's.
