Quicksilver 3000 Classic controller question - what stops the move wires from wear?
Wave thumper
Hi,
I purchased a good used Mercruiser Alpha one Generation 2 drive for a conversion on my former jet boat.
I have assembled the controller which came with the drive (Quicksilver 3000 Classic) but when I move the throttle lever forward and reverse I can feel resistance from the wires catching on something.
I closer look at the wires reveals scratching of the insulation.
Please see the pics and provide advice.
I am sure there must be a missing part to prevent the wires from touching sharp edges.
Regards,
AD
IMG00114-20120722-1045.jpgIMG00113-20120722-1045.jpgIMG00110-20120722-1044.jpgIMG00111-20120722-1044.jpg
Bt Doctur
Re: Quicksilver 3000 Classic controller question - what stops the move wires from wea
most controllers wrap the trim wiring around the shaft once or twice then mount the handel
Wave thumper
thanks for the advice BT.
Does anyone have a oem manual for that handle? Its a quicksilver 3000 classic
minuteman62-64
I found a pdf on the Mercury web site that covered a number of controllers including the 3000 Commander. You'll probably find another pdf on the same site that covers the 3000 Classic.
Wave thumper
Still no luck finding the manual, can anyone else assist?
minuteman62-64
I went back to the Mercury site where I "remembered" finding the pdf. Now I can't find it :( Maybe I got it somewhere else. I'll see if I can figure it out and let you know.
minuteman62-64
Here's where I found the manual that I downloaded: https://docs.google.com/file/d/0B1T...BhYy00MjlmLTg5NzktMjQyZDJhMGQ3YzQ1/edit?pli=1
Got it from an iboars thread about a year ago. As I noted, doesn't appear to cover the 3000 Classic. Is the 3000 Commander similar? Or, maybe you can backtrack from the above link to find a pdf that does cover the Classic?
Wave thumper
you are a legend Minuteman!
Actually my controller appears to be in that manual (or at least something very similar).
Thanks to this manual I confirmed there are no missing pieces.
The wires still don't move freely when you move the shaft to forward and reverse. I may need to file back the sharp edges and use a plastic sleeve to protect the wires from wear.
I note the 4000 model features a huge hole for the wires to pass through without any edges to catch on.
