Re: quicksilver 3000 housing assembly
Getting closer. Here are some pictures of what I have.
Need to know if the pin through the splined shaft is supposed to be like this or should it be straight?
Does the pin actually a drive rod?
Meaning does it engage into the slot below?
The 6 small strips at the bottom right fell out of the part. I'm assuming that these are shims, but where do the go?
Is the washer supposed to be 2 halfs? Does it alaign over the pin?
The complete assembly is part # 827270a27 which appears to be an obsolete part. Is there a direct replacement?
Wife is tired of paddling back to shore and won't get back into the boat till it's repaired properly.
That may not be a bad thing in the long run as it would be a little qieter when fishing
