Re: Quicksilver Gear Lube? Please Advise
Wow..... Take the drive off check for
Leaks.... I mean yeah if your a marina that would be great but
The guys a little low on gear oil lets not get crazy Top her off and go
Have fun
It's a new boat to him... He doesn't know what oil is currently in there... and he has no service history... Pulling the leg and even just looking inside would be the very LEAST I would be doing!!!
What I would be doing with a 4 year old engine I have no clue on the history of would be:-
Engine oil and filter change
Fuel filter change
Pull the leg and check the alignment
Visually inspect all the bellows (while the leg is off so I could look inside the uni bellows)
Check engine alignment
Drain leg oil, split leg and check water pump impeller
Fill leg with High Performance Gear lube
That's where I would be starting... Take it from there if I find any problems.... The last place you want to find out the deal wasn't so sweet is half way across some deserted stretch of ocean, with big greenies curling up behind you.
Chris....
