buffbenj
Thread starter- Joined
- Jan 30, 2012
- 33
I have a generation one Alpha one 1987 Quicksilver shifter. I cannot throttle in neutral to help start my 3L engine. Fortunately I can throttle into gear, forward and reverse, but the carb seems thirsty on starting, and I have to disconnect the throttle linkage and manually rev the engine to effectively start it. I have diligently researched this issue in the forums, and there are good descriptions of how to remove the throttle arm, but how does this throttle button pin work, and what does it look like? I found this parts diagram, and I wonder if part #12 is the pin, but this diagram seems vague and certainly not descriptive. Is there a spring behind the pin? I want to know what I am opening before I starting tearing my shifter apart to even try to lubricate the pin.http://www.perfprotech.com/store/assembly/REMOTE-CONTROL-ASSY,1989-90.aspx#assembly This may seem like beating a dead horse, but no one seems to know the mechanism behind how this pin/button disengages the shifter cable from the throttle control arm.
