Quicksilver throttle control diagram
dlogvine
While upholstering the side panels on 1993 Bayliner Capri 185, I removed the throttle control unit and removed the back panel. When assembled, the control did not function properly and is working in reverse order, when lever is pushed forward the linkage is closing the carburetor pump and vice versa. I probably could figure out how to put it back correctly, but will prefer to use the diagram this time. Could anybody post the assembly/ parts diagram or post the link to the schematics. Thx. The picture of the control unit is attached,
dlogvine
[No message]
dlogvine
Problem resolved, when I took the throttle box apart, I saw that the linking between the lever and the throttle cables was hooked up incorrectly and the cable going to the carburator was way too short. When I corrected the position of the link, the throttle cables got the right length and the throttle lever started working as it was supposed to.
GA_Boater
Who needs stinkin' instructions? :lol:
Good to see you got it working again. I have trouble finding diagrams for that remote. :duh:
