Doug Roy
Thread starter- Joined
- Sep 27, 2010
- 45
I've owned this 1992 22' cruiser for a year now. It has a Quicksilver steering wheel and throttle/shift controls but a Volvo Penta engine and outdrive, so the original MerCruiser power plant was replaced prior to my purchase. My problem is with engine throttle control. Both throttle and shift cables are brand new. Shifting is nice and smooth with no problems, but on the throttle there is a "no man's land" between about 1,400 and maybe 3,000 rpms where the throttle lever just doesn't want to stay. It wants to fall back to the 1,400 position anytime I release pressure. Engine throttle does NOT stick. I get immediate response to any throttle lever movement. The control just applies strong pressure back and will not stay in position upon release until you reach around 3,000 rpm's. From then on it adjusts nicely. Same deal coming from high power to low. As soon as the rpm's get down under 2,500 the lever wants to "pop" way down and put me back at about 1,400 rpm's again. Throttle adjustments at the carb are free and smooth. What could be going on in the Quicksilver control mechanism that would cause this? Is it worth trying to fix or should I just replace it?
I don't know the model number but here is a pic.
Thanks!
Thanks!
