sutor623
- Joined
- May 23, 2011
- 4,089
So got the new powerhead on the '95 v4 Looper 130 and boy was it hard to start up the first time. Was cackling and coughing, and not starting. Anyways I let it set for a bit, then drained the water from the tub and fired her up on the muffs. Once started, she ran like a dream. Ran it long enough to warm it up, and check idle timing. Last powerhead like 6 degrees ATDC at idle so I figured it was a good starting point.
Now that it was warmed up I put it in a bucket and it started just fine. But, I noticed that quickstart would engage and disengage erratically until either A) the motor was warmed past 96 degrees or B) I physically grounded the white/black wire to ground. Even after the white/black wire was grounded, it would still go in and out of quickstart erratically for a few seconds. I disconnected the yellow/red wire and started it up and it STILL went into its erratic quickstart dance. I know that with that yellow wire disconnected it should not even TRY to go into quickstart. There is no voltage coming in on that wire unless the key is being turned. I checked all the CDI checkpoints with no love. This powerpack is 3 months old and the stator is brand new CDI.
Anyone else have an idea on what to check? Does it sound like I have a faulty powerpack? I dont mind just grounding out quickstart, but the motor will not start easily with the erratic dancing, plus I know it cant be good for my new powerhead.
