Quickstraight prop shaft repair in Louisville
maddog2112
Does anyone know anyone who uses the quickstraight, prop shaft straightening hydraulic system in the Louisville ky area. I hit a rock in shallow water and slightly bent the prop shaft on my Q6. I thought it was just a bent prop, but after I replaced it, I can see a slight wobble when spinning the prop by hand. There is no lower unit leakage yet, just a slight and annoying vibration at low speeds?
