JSGOLD
Thread starter- Joined
- Sep 22, 2009
- 609
Our new to us 84' Evinrude 8hp longshaft (E8RLCRM) pull starter froze up on me while trying to launch Saturday....busy day too.:facepalm:...Anyway we used the electric trolling motor to get us away from the dock area and worked with it a bit. I had noticed that when I first started to pull the motor over the starter was making a slipping noise. The motor did not start on the first two pulls and then on the third it totally locked. When I removed the cover I saw no damage. I found that moving a flat black plastic part out of the way would let the starter turn again, so I put a screwdriver into the hole to hold it and started the motor up. Left the cover off. I figured this was how I would have to start later on, but it actually started OK later on with no further issues. Are these types of starters a pain or is mine just in need of repair or replacement? There is little wear on this motor, was used very little.
