- Joined
- Mar 8, 2009
- 44,792
In short: Measuring Radon between 4.1 to 4.5
Basement Tub was installed over gravel base. Concrete is all around it and as to why they did it this way is anyone's guess. Have access to drain side of tub and looking for a way to seal under the tub without removing the tub.
Think about floor leveler, mix large amount and pour under drain end. Not sure if it would make it around all sides and the rear. Also don't think leveler will actually seal anything.
Is there anything on the market that way do what I'm looking for
Have a electronic Radon meter which is listed as highly accurate, is reset-able so it can be moved to other locations for new test. Have moved it around up and down stairs and most all are in the 4.1 to 4.5, max by EPA is 4.0. Did test outside air on porch with 0.5
