BDM Boating
Thread starter- Joined
- Apr 7, 2009
- 3
I have a 1997 Mercruiser 5.7 with a Freeze plug that poped out because I am stupid and didn't stick a wire in the drain hole. The plug is located directly over the engine mount on the front of the engine. I need to raise the engine about an inch to insert a new plug. What would I need to remove other thatn the two mounting brakets on the front to lift the engine?
I hope that the block did not crack internally but I need to get the new plug in to verify.
Or does anyone have an idea on what type of tool I could use to insert a new brass plug. It will slide in the space and will give me the room to fit something the size of a flat head under the plug.
