MikDee
Banned
- Joined
- Jun 6, 2007
- 4,745
Re: Raising an outboard?
It's hard to see clearly because of the shadows in the Pics, but in the 1st one it looks like your cavitation plate is too low (below the bottom) of the boat, this would cause the roosters. If your motor is held on by clamps, (not bolted) I've seen high speed water pressure push up, and lift the engine right off the boat!
run a straightedge from the bottom of the boat to the cav plate, and try to get the cav plate even with, or slightly above the bottom of the boat. Also, the motor angle must be paralell with the hull before you do this, (besides that is the best setting to start out with).
