Gary H NC
- Joined
- Dec 1, 2005
- 8,972
From my shakedown cruise thread Studley suggested checking engine height because of my wot only being 5100 rpm. I did some measurements and the cav plate is about 1 1/2 inches below the centerline of the hull.The engine does have another hole that i can raise it an inch or so. What is the best way to lift the engine and what do i use to put on top of the transom for the engine bracket to set on? I assume i don't want the weight of the engine supported by the bolts only.And i think re-sealing all the bolts with 5200 would be needed also? Also i think jacking it up by the skeg is a big no?
