JoLin
Thread starter- Joined
- Aug 18, 2007
- 5,146
Did the link 'n sync and motor (1995 175 hp carb'd powerhead) is running like a top. However, my idle in neutral dropped to 600 rpm (500 in gear). The manual suggested advancing idle timing from 6 deg. ATDC to 4 deg. ATDC to increase idle speed if it's too low. I did that and picked up 100 rpm, but it isn't quite enough. I want to get to about 900 rpm in neutral, 700-800 rpm in gear. The idle timing doohickey won't let me advance timing any farther.
I can run all day if I bump the rpm's in gear to 800, but extended idle time in gear at the current setting (600) causes the motor to start stumbling and stalling after awhile.
Everything seems to be positioned perfectly- butterflies are closed at idle, timing advance and carb opening positions are well sync'd, control cables are new and work smoothly. I tried playing with the trunnion nut on the throttle cable, but that screws up other positioning and the the high idle lever stops functioning.
Any tips?
Any tips?
