Raising outboard higher
SirFaffer
Hi all, have a 4.21m tinny with a 30hp etec on the back at on the tallest bolt holes I'm still dragging the anti cav plate through water, which is suggesting drag. My top speed is suffering and im topping out at 38kph with two people and all of our gear.
Am trying to decide between having my transom extended or running a riser/jack plate, so was wondering if any of the following would be suitable.
Also toying with the idea of going a lower pitch prop as I'm only hitting 5400rpm, but accept that maybe that'll change with the outboard up a bit higher?
Cheers :)
airshot
When a straight edge is pushed up against the bottom of your hull, and the motor is tilted so the cav plate is parallel to the straight edge.....how high or low to the hull bottom is the cav plate ?? This should be your initial starting point. If cav plate is level with hull bottom, moving it up or down won't do much without customizing your prop. Adjust your prop pitch so your motor reaches max rpm with just you and basic equipment on board. If you choose to make changes to the motors height, the jack plate is the best way to go, other than the cost !! Also be sure your motor is running at top performance, or you will be starting over with your setup.
Gee, can you put a 2X2 between the motor and transom to raise it up a bit?
jimmbo
If it is Bolted to the Transom, there is no Need for any spacer. If it is just fastened with the Clamp Screws, you have to be careful as to how high you go. Too high and the Engine will be at increased Risk of coming off the Transom, due to lack of Clamping Area
By chance are you trying to install a long shaft(20") motor on a 15" Transom, or an extra long shaft(25") motor on a 20" Transom?
Some Pics, from the Side, and Rear, taken Level, down at the Height of the Hull Bottom, which the Motor Positioned like mentioned in Post #2, will give us a better insight...
SirFaffer
Yeah it's not quite level.
It's bolted on.
I'll grab pics tomorrow. Long shaft hull, 20" leg.
jimmbo
One Caveat regarding placing the AV Plate even/level with the Hull Bottom. This an Aluminium Hull, if it has a Protruding Keel, that will require the Motor be lower than on, a Fiberglass Hull, which usually don't have a protruding Keel
Many years ago I had a long shaft '79 Evinrude on a mid-80s Fisher boat. The plate was a few inches below the hull. Since it was a clamp on, I really couldn't really go higher as jimmbo noted. However, I bought a piece of 2x2 aluminum tube along with two scraps of flat aluminum, had my buddy weld them together, and bolted my lift to the transom. It definitely made a difference in how that motor performed.
If I would have had the money though, a jackplate would have been the smarter move.
airshot
It's bolted on.
What do you mean, not quite level ?? You adjust the motor trim until it is parellel to the bottom. This is just a starting point....is cav plate even, above or below the hull ?
SirFaffer
Problem solved.. put a 50hp on it and used a proper template for the transom holes. Previous outboard had a different bracket with less adjustability.
