muskyfins
Thread starter- Joined
- Jun 7, 2012
- 587
Details:
1993 Stingray 606 (20' open bow)
188/888 mercruiser (not original to boat)
current prop 13-3/4? x 19P 3 blade ss (model 48-88440-19)
runs 42 mph (GPS) at 4200 rpm trimmed up with about 600 pounds of people and 15 gals of gas
Problem:
Cannot take off from idle. Even if I slowly advance the throttle it would suddenly rev fast and no forward motion as if the hub was spun. If I VERY SLOWLY (couple hundred RPM at a time) advance the throttle, eventually she'll get on plane and all problems are gone.
Prop shop says hub not spun but old prop has too low of rake angle (8 degrees) causing prop to slip. Reccomends 4 blade 21P alum "for more stern lift." I didn't think I had a stern lift issue?
I am looking for a compromise of both top end and hole shot. We're on the Fox Chain in Illinois and if you're familiar with it you know you need to be able to get on plane in a tough chop caused by the sheer number of boats out there. I also like to run fast but would settle for 42 mph if that was the compromise. (Many say the stingray hull with a V-8 is capable of more like 55 mph-Singray even advertised it as such with a 23P prop)
So I sort of have a benchmark with my old prop but have no idea how my actual hole shot would be. Is there a semi-scientific formula to get closer to a starting point? 3 Blade/4 Blade? Aluminum/Stainless? How pitch factors into either of the first two equations? It's starting to make my head hurt....
Problem:
