raker 19 pitch
walleyehed
Re: raker 19 pitch
You must understand the load on the engine in relation to the throttle plates.
If you have so much pitch that it takes wide open throttle to achieve 5000RPM, then drop a couple of inches and you will note that at 5000RPM, the plates are only partially open indicating it requires less fuel at that RPM-keep in mind that RPM is the figure we go by for optimum engine life, speed is only a result of how efficient we have made the set-up. You may be slightly slower at the same RPM with less pitch, but economy and engine life go up...AND....if set-up with the correct prop, you can have the RPM and speed both but you must be willing to "tweak" the total set-up.
marty f
Re: raker 19 pitch
i just took my old prop off and its an 13 tooth spline and they do not sell much for that just 15 tooth no stilettos will work i guess any suggestions
marty f
Re: raker 19 pitch
the saga is over just received my new stilletto 17p gained 4mph and the motor is running at 5000 rpm works perfect in all occasions thanks walleyehead
walleyehed
Re: raker 19 pitch
If your happy with the figures, that's ok, but be aware that 5000RPM is lugging the engine....the reason I suggested a 15P and maybe even raise the engine some.
