copelandcf
Thread starter- Joined
- Aug 26, 2008
- 28
I have been in the process of replacing my waterpump and waterpocket cover after a burnout on my Alpha One. Finally everything is back together. I started it up to run it (yes there is gear oil) and the drive is making a rattling noise, not sure how much rattle is normal as I am new to boats. I did a search and if the trim is up it seems the u-joint can make a rattling noise, correct? My trim was pretty high and did not know this is an issue. I ran it mostly in neutral, but did put it in drive to make sure everything was working. I did rev it up to 3K rpms a couple times to make sure it wouldnt overheat. Could I have done any damage to the drive? Total run time with trim up was 5-10 minutes, with only 1-2 of those over 2K rpms. Wish I would have had this knowledge before hand. Thanks for any help. Cavan
Also when I pumped in the gear oil, one quart did not make it come out the vent, should I get more? I thought Alpha One only needed one quart of gear oil.
