ranger 350 v w/ yamaha pro v 150
rdnk_4_lf
we are buying a boat in the near future and it is a 19 foot ranger 350 v with grand national on the side. it has a yamaha 150 pro v and i was juss wandering if there is anything i need 2 look at on the motor. it ran when the guy parked it but its been sitting for about 2 years. any help will do bty boat is in great shape and motor looks great.
triumphrick
Re: ranger 350 v w/ yamaha pro v 150
I would not start it with the gas that is in the boat. I would find a way to drain that. I would drain the lu oil and refill. Pull and check the plugs. Replace with NGK only. Replace the engine fuel filter. Also replace or add a water/fuel seperator if there isn't one. Using a remote tank I would do a seafoam treatment.
After that I would make sure the impeller is giving a strong tell tale. If not they are easy to change.
Pull the prop, grease the splines.
Give the motor a good spray of WD-40 or silicone on the inside parts. Avoid the thermostats.
Sea foam..A far as cleaning and maintaining your carbs, you definately have to take them off and apart, no other way to get into all the little orifices and jets. If you d like to periodically de carb your ENGINE , seafoam is a good product.
in a portable tank, mix 3/4 gallons of premix gas, an 3/4 can of seafoam, (assuming you don't have the vro connected). Put the remaining seafoam in a spray bottle, run the motor up to temperture, remove the plugs, one at a time, spray some seafoam into each cylinder and replace plug. let sit 15 minutes, remove the air silencer from the carb while waiting, restart motor, and spray seafoam into each carb, until it start to stall. repeat till seafoam is gone. run out the rest of the gas. it is going to smoke like it is on fire, and drip goo on the ground. replace the plugs with new ones, and then do the compression check again. this procedure burns the carbon out of the motor and been known to free up rings, and increase compression
rdnk_4_lf
alright, thanks i rekon we're takin it 2 a mechanic and let him clean the carbs and we will drain the gas in it and put fresh. any suggestions on oil, we used quicksilver in our mercs. and definately change the lu fluid...... :)
