GMCanuck
Thread starter- Joined
- Apr 23, 2017
- 11
Hey Folks - new member, first post.
Boat: 2004 Alumacraft Navigator 165 tiller
Motor: 2004 Mercury 50hp ELPTO oil-injected 2-stroke
Question: Should my prop shaft "ratchet" when gear selector is in Reverse?
I had my prop shaft out of the bottom end this weekend to check on the general condition of the gears, seals, etc. Found all to be in order, so put it all back together. Moved the shifter through the gears, hand-spinning the prop to make sure all felt normal.
Neutral - free-spinning
Forward - locked counter-clockwise, ratchet clockwise
Reverse - locked both directions
Seemed to recall the prop ratcheting in Reverse before as well, so took it apart again to see how the whole thing actually works, with the "dog clutch", etc. Figured there's no way the dog could ratchet in reverse, because the gears are pushed tight together when in Reverse (no spring-loading like in Forward).
So searched around (including on this site) and found hints that while other motors will ratchet in Reverse, Mercury's typically do not. Had this confirmed by a local boat shop yesterday, but just wanted to follow-up with this community as well. And if nothing else, provide this clarification to others that are curious.
So, does this sound normal to everyone?
Thanks in advance.
GMCanuck
Thanks in advance.
GMCanuck
