Re: Rattle in Mercury 40EO
Low octane, lean mix, timing advanced too far, wrong prop causing lugging. These can cause detonation. Sometimes this sounds like a rattle.
If that's what it is, it'll eventually burn down the motor. I'd have a pro look at it, or dig into it yourself to be sure it's right.
I,m fussy. I change props to pull water skiiers with a 150, just because the motor sounds happier with it.
hope it helps
John
