Re: Raw water cooling to fresh?
The other good things about closed cooling are that you can run a 180 deg thermostat, which provides much more efficient combustion temperature. Also closed cooling systems eliminate the radical engine block expansion and contraction from eliminating the intrusion of cold raw water into the block. This is immeasurably easier on head gaskets, cylinder walla and piston ring wear.
