raw water pump pulleys
tmcdonough
replaced raw water pump on 3.0 mercruiser. Having problem removing V-belt pullleys from old pump. Got 4 cap screws out, but pulley seems to be stuck on pump shaft. Just need a little persuasion?
cr2k
Re: raw water pump pulleys
Probably. A plastic or dead blow wammer.
tmcdonough
That's the trick. A good tap with hammer and it came loose, thanks.
