summers1996
- Joined
- Nov 2, 2005
- 30
Rodbolt and Ray, thanks for the help on my engine rebuild. All worked out well. My concern is; when overhauling the carbs I found the floats adjusted very high. About 3/8 of an inch higher than the manual recommends. (not at all "level with the carb mating surface" as stated in the manual). I had a hole in a piston that I attributed to a lean condition. Now I have just re-adjusted my carbs to a leaner condition ...right? Do either of you know any reason that a carb float would be adjusted so high? It looked as though the floats were not even adjusted, just popped in right out of the box. Could a very rich condition cause a hole in a piston also??? These are Mikuni carbs.
