Re: Re Bored Evinrude 70, Carb Jet Change?
Thanks anyways Rdav!! If you're ever up in Manitoba I'll buy you a cold one!<br /><br />Funny you mention the tell-tale bulletin, the rebore shop actually took a hole punch to mark the spot on the block where it should be drilled. Think 24/26 drill bit and 1/8 pipe tap is what they state to use. Been planning on making the mod, just want her running good before I start worrying about the little stuff. I have tested the overhead sensor and so far no problems...<br /><br />Voodoo.... I would guess the standard 19?? I know my 1990 70HP is 19 degrees BTDC.
