phillnjack2
Ensign
Thread starter- Joined
- Apr 30, 2011
- 918
Model no BE60TLEOC 1995 3 cylinder .
My engine at the moment is running sweet
but i have a Identical almost complete spare engine that has scored bore and a badly chewed up piston.
im thinking about a complete re-build of the block over the winter/spring period and wondering what the cost might be.
Also i need to know if its best to use original omc/Brp parts or other makes of stuff for this project.
i am hoping the bore can be taken out enough to go past the scores, but if not can this block be sleeved ?
i will be checking the crank to make sure its not oval and in good condition.
the scored bore is the middle of the 3 and is pretty bad to be honest, i just hope not too bad and the block junk.
the cylinder head i will have skimmed after i polish the inside of the compression chamber to get rid of any marks left by the broken ring/piston.
the damage was caused by either no cooling or no oil, i am 99.9% the vro on this engine had gone bad or got blocked.
I of the rods for sure is bad as its gone rusty since being taken out and left in a box.
so ill probably be looking for 1 rod 3 pistons and rings plus ofcourse all new bearings for the crank while its down.
are wiseco as good as oem or better ?
is the block ok for sleeving ?
i think i can get 40 thou oversize at a push, is this the very max ?
phill.....
phill.....
