noclutch
Thread starter- Joined
- Feb 1, 2013
- 104
I found that my OEM Farina transducer had detached from the hull after experiencing erratic readings. The epoxy that it was glued down with is still completely adherant to the underside of transducer, just not the hull. It appears that the manufacturer had sprayed the inside of the hull with with a thin white gel coat layer that was too slick for the epoxy to stick to. The epoxy is black and about as hard as plastic.
Suggestions on what type of epoxy to use to re-attach the epoxied transducer to the hull? Of course I was going to de-grease then roughen the surfaces prior. FWIW the original transducer was placed fairly far forward in the hull but still came in contact with oily bilge water that sloshed foreward, which probably hastened it's detachment, thus an oil resistant epoxy I assume will be indicated.
Thanks!
Thanks!
